I'm having my central heating/hot water system updated. The existing system is an ancient potterton boiler and vented cylinder. I want to change to a new boiler and unvented cylinder.
It's a 2 person, 4 bed mid-terrace property with 8 radiators, one bathroom, one shower room and a cloakroom.
The engineer has recommended an 18kw system boiler and 150l indirect gledhill cylinder. Do these sound reasonable?
My only concern is that the existing cylinder is fitted in a cupboard in the eaves of the roof and the space is quite tight. We've discussed several possibilities.
1. Fit the 150l cylinder in the same location. The cylinder may have to move further into the room which would mean that the cupboard would need expanding/boxing. The ceiling has already been cut away to make room for the existing unvented cylinder.
2. Fit 2 90l cylinders which are small enough to fit into the cupboard.
3. Fit a 180l horizontal cylinder.
Can anyone help with the advantages/disadvantages of these possibilities? I'm leaning towards a 180l horizontal cylinder, but I don't know if there is a significant difference from vertical cylinders? I read that they're less efficient, but that would be OK if the difference isn't too great.
The 2 x 90l cylinders is a nice idea, would this mean 2 expansion tanks too? Would this increase complexity? I guess there are 2 cylinders to go wrong, but maybe we would have added redundancy since we could manage with one if there was a problem with the other?
Let me know if you need more info.
Thanks,
Dan
Thanks,
Dan
