Partly right.would i be right in thinking 20 mbar is 0.002 bar? so less than 1psi?
i just seen most boilers seem to accept gas at 20mbar and was just curious what pressure that was. i guess the pressure before the metter is alot higher otherwise they would have massive pressure drop over long pipe runs.
Note that you can always use the amazing Google unit converter for this sort of stuff, so stick "20mb in psi" into a Google search and you get the correct answer back.
Does all sorts of unit conversion including all sorts of esoteric ones like "2 furlongs in metres" or "3 light years in parsecs"
There is also a full calculator and currency converter in there as well so "50GBP in USD" works as expected, and (1+sqrt(5))/2 all do the right thing![]()
