My house was built around 1980, and water mains is supplied via 22mm plastic pipe. At the entrance, it is reduced to 15mm copper which is used throughout the house. I will be changing pipework inside the house soon. My options are:
1. Easiest one: use 15mm plastic from the stopcock. Leave the rest unchanged.
2. Slightly more expensive: use 22mm plastic for every pipe that supplies more than one point, however keep a small run of 15mm copper to the stopcock.
3. Replace the stopcock and the short run of the copper pipe to it with 22mm, and use 22mm elsewhere (as above).
The static water pressure here is 3.1 bar. The short run of copper to the stopcock is about 1m, and the run of the 22mm plastic supply is about 7m. I am currently getting about 12-13 litres per minute. A plumber told me that I will not get any better flow by changing stopcock/internal pipes (in other words, it is the supply pipe that restricts the flow). Is he right?
