    Dismiss Notice
25mm blanking cap/plug
Discussion in 'Plumbing and Central Heating' started by garyo, 19 Feb 2018.
  1. garyo
    garyo
    11 Apr 2006
    2,126
    Thanks Received:
    197
    Berkshire
    Country:
    I bought a few of these strainer kits at the start of a kitchen project, and now that I've worked out which sinks are being fitted etc, it turns out that I don't need the overflow feed on one of them. The thread measures around 35mm outside diameter. Do I stand a chance of getting a cap for it to blank it off or do I just need write it off? I still have the compression fitting and conical washer for it, so a ~25mm blanking plug would also do. Am I likely to be able to find one? (i can't see any that small at the obvious online retailers)
    Gary
    [​IMG]
  2. Sponsored Links
  3. Nige F
    Nige F
    28 Jun 2005
    21,197
    Thanks Received:
    1,741
    Country:
    Probably easier to get a basket strainer waste from screwfix - number 97562 - without overflow;) about £7
  4. garyo
    garyo
    11 Apr 2006
    2,126
    Thanks Received:
    197
    Berkshire
    Country:
    But think of the land fill...
    • Like Like x 1
  5. endecotp
    endecotp
    2 Dec 2013
    3,949
    Thanks Received:
    507
    Country:
  6. HERTS P&D
    HERTS P&D
    9 Apr 2010
    12,918
    Thanks Received:
    1,980
    Hertfordshire
    Country:
    Plastic bag and a cable tie. (until you bought a new trap or blanking cap)
    Andy
    • Like Like x 1
  7. Sponsored Links
  8. ReganAndCarter
    ReganAndCarter
    13 Sep 2010
    3,931
    Thanks Received:
    387
    Sick Man Of Europe
    Country:
    As endecotp says, use the screw/nut part that screws onto the thread and bin the flexi hose. Make up a plastic disc of the right size and place it in the nut with some silicone around the endge of the disc. Screw it on and wait for silicone to set.
  9. garyo
    garyo
    11 Apr 2006
    2,126
    Thanks Received:
    197
    Berkshire
    Country:
    I'll get the vernier on it tonight and confirm. Hopefully you're right, in which case it seems pretty ubiquitous at £1.50 incl postage.
    I did also consider using the nut and pipe that I have to connect it to the washing machine connection on the other side, but I couldn't bring myself to do it...
  10. Madrab
    Madrab
    4 Oct 2012
    8,036
    Thanks Received:
    2,274
    East Renfrewshire
    Country:
    Fill it full of silicone adhesive and cover the end with gaffer tape till it sets for a proper bodge ;)
    • Like Like x 1
  11. endecotp
    endecotp
    2 Dec 2013
    3,949
    Thanks Received:
    507
    Country:
    Genius idea.
  12. garyo
    garyo
    11 Apr 2006
    2,126
    Thanks Received:
    197
    Berkshire
    Country:
    Problem solved. Unfortunately the thread didn't match the appliance thread on the other side, but I managed to find some 25mm plastic bar in the garage that fits a treat.
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
