25mm Plasson fittings
16 Jul 2009
Hull
It says online that this only needs to be hand tight, is it best off to give a small nip with a pair of grips. Also, to get the fitting on, do you need to demount the fitting and slide the nut and grab ring on to the pipe first. Thanks
Wouldn’t do any harm
Possibly, been years since I’ve used one, not much call for them in a breakdown engineer role! :ROFLMAO:
