28 cdi fault
14 Dec 2009
Hi can anyone help!
My 28cdi has an intermitant fault where the tap light flashes fast in DHW or CH mode and I then lose heat this happens mainly in the morning when I put the DHW on. Any ideas want it could be.
anything and everything
from pcb to slightly sticking diverter vavle impossible to say as part is going but without being their when it`s broke i could not give definite answer
I spoke the an engineer and he said it sounds like the pressure switch
if you got manufacture instruction you could have look in their and might tell you just rembered some worster use flasing light`s as fault code bit annoying though
standard or HE CDi?
if standard will look up the codes for you as have manual
if HE then try worcester's website
Its a 28 cdi RSF The book indicates fail point j "Air Pressure Fault"
fairly cheap fix get local bod to change it in the morning if the fault is with
the presure switch never rule out pcb though
yep fast flashing hot water light is a slow fan or air pressure swith or one of the pressure switch tubes cracked / split. Does it do it during a demand....is the fan noisy?
Only on demand the fan doesnt seem noisey and seems to happen more when cold
