28cdi, gaining pressure?
1 Apr 2005
hi guys, got called to a w/bosch 28cdi yesterday, apparently gaining pressure overnight and opening the p.r.v.
filling key was not left in, expansion vessel is ok, p.rv is operating correctly (obviously!).
watched it running for about half' hour yesterday, and pressure seemed stable under all conditions, and its not a large install, so the expansion vessel is more that enough, so the only conclusion i can come to is that the cold feed is passing through to the heating circuit within the boiler.
Diverter valve?
D.H.W heat exchanger?
anyone who's had this before, you comments would be great!!
cheers pete
calorifier passing mains pressure into heating circuit usually.
calorifier
plate heat exchanger
secondary heat exchanger
water to water heat exchanger
call it what you will I just go for the quickest one to type :wink:
If you ring worcester they list it as a plate heat exchanger.
