- Joined
- 19 Jan 2024
- Messages
- 47
- Reaction score
- 6
- Country
I'm plasterboarding the stairs, and as always in this 1950s build, I banged all the old plaster off back to the brick, and the wall are massively out in all directions, but notably, there's a bulge in the middle, almost all the way up. I was going to use plasterboard adhesive, but to use 12.5mm boards and miss the bulge, I'd be coming off the wall at the top and bottom, anything up to 32mm including the plasterboard. The stairs are also not straight, along the wall, with a large bow inwards in half way up. I can't really come out any further, because of the stair stringers, so 32mm seems to be the sweet spot. That would mean battens of 20mm ish and shorter PB screws.
My question is, would battens of this size, be ok for 12.5mm plasterboard or will there be a problem with it moving etc? Or, should I just use the adhesive and use more of it and the top and bottom? I read somewhere that 20mm and above with adhesive can make it weak? Not starting for a week or so, so probably over thinking it. Any help is much appreciated, cheers.
