Brick wall is double brick width and pretty sturdy. It's only 4ft high, so want to extend to 6ft.
I bought some post brackets that have a flange on each side, they screw down onto the wall. Should I squirt some outdoor sealant in the holes first, to stop water finding it's way inside the wall and causing problems?
I want to use 150mm feather board horizontally. Posts at 1.8m centres. I was going to also fix some vertical battens to the backside, in between each post, so as to prevent too much warping. Will the battens help? 30mm overlap on the boards.
