3 inch stack
6 Feb 2010
Blackpool
I have a new toilet to connect to a 3 inch cast stack. It used to have a toilet connected on it before via Lead pipe. Would most recommend a new stack or connecting on to the 3 in branch of the stack collar. And converting to plastic.
3 inch is a bit small, I'd replace the stack rather than try and connect to the old one.
Dig to expose the drain at ground level, shouldn't be deep, and connect the new stack into the drain, which should be 4".
