Hi, everybody.
My CH system uses a Satcwell Duoval 3601 Actuator which I have today
disassembled and found the nylon coupling has split, so it will not rotate
the valve shaft which is free to turn by hand. I know that the motor windings and the valve are O.K. and that renewing the coupling would
restore the system to normal operation.
It's very unlikely that I will find a coupling, unless it is salvaged from an
actuator which has been removed for another reason. Anybody got one?
The obvious solution is to renew the actiuator but I can't find information
regarding direct replacement compatibility of those which are available.
I believe that Satchwell now go under the name of Sunvic and they make
3 port, 4 Wire actuators, as do other manufacturers but which one do I
order to replace mine? Come on guys - share your knowledge.
Thanks for reading this.
