Recommend replacement for Sunvic 2-port Mo-Mo actuator ?
8 Jun 2011
Manchester
The Problem
The 2-port valve and Mo-Mo Actuator on my Central Heating system often stick when moving between the “open” and “closed” positions.
[Actually, the actuator doesn’t stall – it simply clicks as the gears jump when there isn’t enough torque to turn the valve shaft.]
System description and History
Uses a Sunvic 2-port valve type ML3501 driven by a Sunvic SM5203 (5-wire) actuator, to turn the Central Heating (CH) on or off. Hot Water (HW) is not controlled – the HW cylinder is heated whenever the boiler is on. Note that the valve is sized for 1-inch inside-diameter pipework – not quite compatible with the modern 28mm outside-diameter pipe size.
The system was originally installed circa 1979 as an open system with a separate header tank, one Satchwell motorised valve and with gravity HW circulation. After a few months, the pipework was re-jigged (using the same valve) so that the pump now drives the water round both CH and HW circuits.
The boiler was replaced (maybe 10 years ago). At this time, the separate header tank was removed and the system changed to a closed one with a pressure vessel.
At around this time (maybe earlier), the original Satchwell valve and actuator were replaced with the Sunvic models described above. I still possess the old valve, but not the old actuator.
Observations
With the actuator separated from the valve, its shaft turns through the 90 degrees between the “open” and “closed” positions in 50 seconds. I’m moderately sure that the old actuator took longer than that – i.e. that it was lower-geared, and so had a greater output torque. I can rotate the valve shaft easily with my fingers, with no obvious point of increased resistance.
At one point I improvised a DIY actuator, using a “Drayton Replacement Synchronous Motor 230V 27010BQ” from B&Q, a gear train, a cam wheel and some microswitches. This was very low-geared, taking 300 seconds to move between positions. It was 100% reliable, but ugly, and I want to find a professional device that works.
The valve plate actually says “use with actuator type SZ” – but as far as I can see, all the “SZ” actuators available are of the “Motor on – spring return” type.
Questions
1. Can anyone recommend a Mo-Mo actuator with sufficiently great torque to operate my [relatively large diameter] valve ? If need be, I could make an adaptor plate to fit the actuator to the valve base.
2. I assume that I could in theory use a spring-return type actuator – all the other wires would be the same but there just wouldn’t be any wire to connect to “CH off”. But wouldn’t this require double the torque from the motor, since it would need not only to turn the valve but also to wind up the spring ? And can I be sure that the wound spring would have enough torque ?
3. Any other ideas ? I want at all costs to avoid having to drain the system.
Sunvic valves are notorious for seizing. Unless you can turn the valve with your fingers you are wasting time and money in fitting new actuators.
New plates and shoes are available as a kit, but that does mean a drain I'm afraid, unless you know how to bung a system.
Thanks, Onetap and 45yearsagasman. To clarify what I was asking...
I don't think my Sunvic actuator is faulty as such, just that it's not up to the job. So I don't think I'm looking for a repair. :(
[I assume that the gear mechanism by which it spills its torque (rather than stalling) is a design feature, and does not represent a failure mode.]
And yes, I can turn the valve easily with my fingers.
What I was asking is if anyone knows of a different make of actuator which would be more likely to succeed ? I should be able to invent any mounting adaptation that may be needed. :)
Dave.
No, the motors are not rated to run for more than a few minutes, maybe a microswitch failure. If the valve is OK, the actuator is defective; recommendations as above.
Other makes of actuator won't fit. I think Drayton (don't remember ) fit, in that the drive shaft is the same shape, but the angles at which the valves open/close are different
