Hi, in my new home I inherited a non fully functioning Baxi gravity HW pumped CH system. There was a 2 port Sunvic valve in the gravity feed that had no actuator fitted and was seized solid in the open position. There was no tank stat fitted either.
I wanted to gain control of the cylinder HW temp and so decided to replace the Sunvic ML 3501 valve like for like and obtained both MOMO SZM1801 and Spring Return SZ2301 Sunvic Actuators (it was cheaper to by the valve body and spring return actuator complete).
I decided on getting the Honewell Y9420S Sundial RF Pack 3 for controller with wireless room and tank stats.
I've discovered now that I'm going to need to fit a relay solution so as to be able to either independently control firing the boiler or ensure the pump is only powered when the CH calls for heat. There aren't sufficient wires / contacts on the Sunvic actuator to do this. My initial thoughts are to use a relay with 2 solenoid windings so either the HW or CH control can fire the boiler. I could use two separate relays but ideally I'd like to use a relay with 2 windings. Any other suggestions gratefully received.
