3 port - which manufacturer?
I expect the Honeywell bodies are cast and finished in India or China just like everything else, probably in the same factory as all the competitors use.
Honeywell and Drayton are the most popular. Honeywell as a package are easier to service if required.
im fitting a sauter made product now, dirt cheap, modular plug and a 5 year warranty, honeywell can **** off.
Apart from being almost impossible to replace the motor and with the plastic bits breaking, its also virtually impossible to separate the head from the body!
Tony it might be specs aver time for you :D
Most Drayton valves I look at, head is removed by press of button :wink:
You are lucky then!
Most failed ones that I go to are the earlier type which are screwed together with screws inacessible without taking all the inside bits out.
