plumbing guys,
I've a faulty actuator on a valve I apparently cannot get anymore so looks like I will be changing the whole valve.
If your looking at the valve, AB (from boiler) enters the left, when actuator was energised, flow came out of A on the right (off to hot water tank), when de-energised it flowed out of B which is the bottom (return to boiler). The valve has threaded connections and is fitted to what I believe are union connections on the pipework (malleable iron I believe)?
I will try get a photo uploaded but my phone is currently flat so will try later. In the meantime can anyone help?
cheers
cheers
