History:
In April 2008 I had a Worcester 42CD combi boiler fitted. Up until that date I never had to bleed the radiators. Despite double dosing the system with Furnox and placing a nail against the magnaclean magnet to confirm that no corrosion was present I have had to bleed 3 radiators once or twice a year. Despite bleeding the rads I did not have to re-pressurise the boiler.
In August this year I had a new bathroom fitted with the old radiator replaced with a towel rail that was moved to an adjoining wall. Again the rads had to be bled a couple of times over the next few weeks but this time water had to be added to increase the pressure. I put this down to the fact that a rad had been moved and replaced.
Around three weeks ago I noticed that the pressure was almost zero so while I was in the mood I shut the magnaclean off and cleaned the magnet. I then forgot to open the valves either side of the magnaclean. The boiler would fire up for a few seconds and then cut out. Not realizing that I had forgotten to open the valves I tried turning the key to add water but nothing happened and so could not increase the pressure. I then remembered to open the valves and could re-pressurise the system and the boiler came to life.
Since then I have had a new kitchen fitted but the rads were not touched although the main incoming cold feed to the boiler had to be re-routed to allow kitchen units to be fitted.
I am now loosing half a bar every couple of days. No sign of leaks as I have gone to every radiator with a tissue and checked the lockshieds, bleed nipples and every exposed joint.
Question, where did this air come from since the combi was installed?
Is it likely that the company that moved the rad has caused a hidden leak?
By me forgetting to open the valves have I cause a leak inside the boiler as I now have an escalating problem that has got worse this week but with not a sign of any leak or leak marks on the walls and ceilings.
