hi, I am having problems with my boiler, the glowworm 30 cxi its approx 7 years old we had a power cut as a result by boiler packed up, initially showing a f13 code, after leaving it shut down for a day or two i restarted it and it started up ok so then I went and turned the hot tap on and the boiler kicked in and heated the water ok, so i turned the hot tap off and as I did, it gave me the f13 again, and would not produce any more hot water after that, so I left it a few hours maybe to cool down as I thought and haypresto it worked and turned on an gave me hot water again, but did exactly the same thing again , once the hot tap was turned off it shutdown and gave a f13, can anyone help please,cheers jd.
