32mm Waste Length - Siphoning Issues?
barney12 said:
chrishutt said:
barney12 said:
I am making the assumption these AAV's can only be mounted horizontally!
On the contrary, AAVs must be mounted vertically. Check this.
Well as your your footer says! :lol:
My not very logical brain assumed it would have to be horizontal. Why does this link them show it horizontally mounted?
http://news.hunterplastics.co.uk/viewitem?newsno=58050&Archive
Rob
But its vertical in your link as well barney :shock: :shock:
barney12 said:
The shower waste is 40mm and enters the stack on its own boss but I'm guessing perhaps flushing the loo or emptying the sink was enough to pull it.
That seems very unlikely, if the shower doesn't share a run with anything. However, do you have a vent on the stack that it enters?
Rob
Oh my simple brain. My excuse is that it was a Bank Holiday :D
The valve is of course verticle. But, the fitting its self is horizontal in the pipe.
............I'll get me coat :wink:
Rob
Yes the stack has an AAV which is within the same room.
Rob
In that case I can't see how anything would pull the water seal out of the shower trap. Is it possible that it's drying out?
Yes, I think you are probably right. Its the guest bathroom and the shower doesn't get used much. I happened to get chatting to a plumber in the merchants today and he said the same thing and said it would be a good idea to fit a HepVO in line to prevent the smells if the trap dries out.
Rob
