No, sorry. This is the updated version of what I've used before. I have not used this one, but its predecessor.
It is more expensive and only has three outputs.
http://www.tlc-direct.co.uk/Products/BLPS3.html[/QUOTE]
Thanks, that's handy, both of them seem to be designed to accept flex which I thought was a bit of a no no in the garden and in my case it will run under a path and a flower bed so SWA is a must. I was planning to use 1.5mm 3 core SWA at least for the supply, but can't find the overall diameter of such cable. The blagdon states a max cable diameter of 9mm so will have to get some 1.5 SWA and see if it fits! The other one makes no mention of the max cable diameter but 2.5mm SWA definatly doesn't fit. The load cables will all be different sizes (pond pump, lights etc) so I will probably use some 20mm conduit with suitable adaptor to connect into the box and keep things nice and tidy. I asked the tech sup line for the one I got if they had any recommendations but they weren't familiar with their product!
