40mm pipe to 200mm square drain
22 Sep 2014
Hey guys,
I'm doing some renovations on my house and the current project is making a simple drain area. It is a simple rectangle shape. Approximately 120x45x50cm. It will be completely tiled, with a drain at the back. And the bottom will be sloped slightly towards the drain.
The problem I have is: the current drain is a simple 20x20cm, which is square, and I need to have a new 40mm PVC pipe drain into that.
I'm wondering what the best way to do this is? I've tried searching for some kind of adaptor, but I haven't found anything.
Perhaps just a sheet of marine ply, and seal it with some silicon?
I've attached some pictures so you get a better idea.
Thanks!
View media item 88577 View media item 88578 View media item 88579
All the adapters appear to be round. As you say some sheet material silicone into place with a 40mm rubber boss adapter through a hole??
