    Dismiss Notice
40mm Waste straight internal joint?
Discussion in 'Plumbing and Central Heating' started by Paul-man, 27 Nov 2015.
  1. Paul-man
    Paul-man
    1 Jul 2007
    288
    Thanks Received:
    2
    Essex
    Country:
    I need to rotate my standpipe in the utility through 90° due to moving my washing machine. However, the I have an elbow which is solvent welded and only an inch or so above the floor.
    I am worried that once i cut the joint off, I wont have enough to get a good joint onto.
    Is there an internal fitting (or other sized pipe?) that I can insert down inside the pipe so that I can extend it upwards?
  2. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,627
    Thanks Received:
    2,382
    Londonderry
    Country:
    Have you got pictures you can upload of the waste pipework.
    Also do you have access to the void beneath the floor.
  3. Sponsored Links
  4. Paul-man
    Paul-man
    1 Jul 2007
    288
    Thanks Received:
    2
    Essex
    Country:
    [​IMG]
    [​IMG]
    [​IMG]
    See above....
  5. Daveydub
    Daveydub
    18 Oct 2013
    1,675
    Thanks Received:
    568
    Gloucestershire
    Country:
    Looks as if you would just about have room for a fitting but if you saw through the elbow, leaving the collar intact, you can then (carefully) saw the collar in a couple of places and drive (carefully) a screwdriver between pipe & collar and remove it in sections.
    • Thanks Thanks x 1
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
