I know how to lap a dpm into a cavity wall on a new build, but is there a chance of damp proofing failure with a single leaf wall?
The idea is to build an non habital dampproof single story outbuilding for storage purposes.
I would plan to lay the edges of the dpm over the top of the brick dpc level but trim the dpm a little short of the full brick so only the black dpc edge would be visible from outside. But this cosmetic trimming could allow water to creep round and apear inside where the wall meets the floor concrete finish.
Is this likely to occur, and if so is there another way to lap the dpm in single leaf construction?
Also, on London clay here, do you think 1 meter depth strip footings would be Ok, and if so what depth and width strip would be suitable? Don't really fancy going for trench fill footings as the concrete cost will be significant.
