5 lever mortice deadlock, or euro cylinder?
20 Nov 2007
Durham
We have just moved, and one of the first things I did was change the locks, fitting our front door and patio door locks with Avocet ABS Euro Cylinders, both keyed alike.
The back door is a wooden item, and has a Yale 5 lever mortice sashlock, and am looking at changing that too. I am torn between replacing it with another lock of the same kind, or changing the sashlock to one that will accept an ABS cylinder, something like this:
https://www.screwfix.com/p/union-euro-profile-mortice-lock-stainless-steel-2-64mm-backset/7950d
Any thoughts?
EDIT: Yes, title should read sashlock, not deadlock :)
you could get them keyed alike.....
That would be the plan, to replace sashlock with the item above and fit a keyed-alike ABS cylinder, as I have done with front door and patio door. I'm really just asking if this will be as secure or better than an ordinary 5 lever sash?
