Had a patio door replaced and have got a 6inch gap (width) all the way around to sort out.
The thickness from the brick the edge of existing plaster is about 15mm.
Was going to put plasterboard in the gap, tape joint between that and existing plaster work and then easifil (already got 1/2 bag)
How should I fix the plasterboard to the brick ? (No space to batten it.)
Thanks.
Thanks.
