I have had a single story extension added to my home
The builder said to get the plastering done before the final screed (sub floor). It has been said in other posts of mine that this was the wrong way round but i had already had the plasterer in.
I was told to chop back any excessive plaster off so that the plaster stopped about 12mm above the final floor level before the screed was laid. This i did but i didnt remove the excess of the plasterboard around the cheeks of the patio doors and also around entrance to the extension
Unfortunately at these points the plasterboard has got wet at the bottom (about 2 inches high)
Also where the floor screed was laid in some places there is an excess of screed under the plaster (it is higher than the floor) and in these places, again the plaster has soaked some water up.
Do i need to remove this excess screed and also the plasterboard so it is above the screed(against touching it). The guy that laid the floor screed said the only reason there is usually a gap between the floor and the plaster is in case the floor gets damp which would then get soaked up by the plaster. He did recommend cutting the excess pasterboard out.
The screed was laid yesterday (friday) and the screed layer said dont walk on it until monday
I am planning on putting in 6inch skirting
