Only up to the 7 pint limit... then it goes downhill rapidly.
Dan_Robinson";p="2344349 said:There are plenty of loonies on here,
Just because it hasn't/isn't leaking doesn't mean to say it won't. [/quote
Same rule then after a pro fit.?.
looking at the state of the copper going into the floor. i would investigate futher. if you have a water meter looking at this, and the black dial moves with no appliances on. will indicate a leak on the cold side maybe hot side if hot is mains fed. if you have a hot water cylinder and cold water storage tank in the loft. isolate the cws or turn the mains off. mark the water level in the cws. and see if the level drops. ps in your pic the pipe nearest has a very bad blob of solder on a T piece. horizontally. on that blob of solder it looks like a blob of water aslo. p.s also check your overflow isnt leaking.
