I have a standard vented heating setup, Boiler is Apollo.
Question 1... how can I tell if my pump is worn or becoming less efficient? It still works but the rads at the far end of the system don't get as hot as they did unless I turn off others in that circuit? (its at least 10 yrs old)
Q2 After the pump on the flow side is a 15mm pipe with a valve between the boiler flow and return. What is this for, and should it be open or closed. Answers much appreciated
