Hi all
Just wanted to pick the brains of the experts to make sure I'm doing this right. I want to build a raised decking area on the patio shown below.
I'd like it to be as close to the level of the french doors step as possible so as to eliminate the step down from the lounge and the step up to the lawn (what's left of it!).
So, the height would be about 300mm above the current patio level. The frame would be about 4m x 2.5m.
I really don't want to dig holes and start concreting posts in so I thought about making a frame from some 6x2 and resting this on 6 mounts made from paving slabs and a few bricks. i.e. patio, then paving slab, then bricks, then frame sitting on top. This should get me to a height of about 300mm.
The mounts would be spaced approx 2m apart lengthways and 2.5m widthways.
Is this all viable?
Should I also fix the frame to the exterior wall? Or will it be ok just resting on the mounts.
A few other bits I guess I will need....
- DPC sheet to prevent weed growth.
- DPC in between bricks and frame to prevent rotting of frame.
- If the frame is fixed to the wall then as it will be above the wall DPC then I should use some shims to eliminate contact with the wall.
I've read and read on this subject but I havent seen many examples of mounting the frame on slabs/bricks so any tips for this would be great.
Cheers all!
Is this all viable?
Cheers all!
