A puzzle for you...
  • Thread starter attractivebrunette
  • Start date
A
attractivebrunette
I got this switch right and I got this socket right...it's for an outside light switch. This is the only switch that controls it.
I took off the old switch plate cos i wanted to put a new flat plate one on but I forgot which wires go where.
So there are two red wires, the black wire is on a block and the earth is wired into the mounting box.
Any ideas?
one red to com or L
the other to L1 or L2
Also the earth needs to be connected to the switch plate, so either cross connect using a CPC(earth wire) or undo earths on back box and fix to switch plate.
As above but next time make a note of how it's connected or take a photo before disconnecting!
You really can't get the hang of switches, can you?:
//www.diynot.com/forums/electrics/another-dimmer-switch-question.290296/
//www.diynot.com/forums/viewtopic.php?t=251202&start=0
//www.diynot.com/forums/viewtopic.php?t=237887&start=0
Is this because:
a) with all those wires and terminals they are fearsomely complicated things to understand
or
b) you simply are not cut out to do electrical work
//www.diynot.com/forums/viewtopic.php?t=138347
//www.diynot.com/forums/viewtopic.php?t=170197
//www.diynot.com/forums/viewtopic.php?t=226941
I vote (b).
