Why on earth should someone have got all offensive about 3-phase power?RF Lighting said:crafty1289 said:someone asked this a few weeks ago. someone will give you a link. ended up spanning about 15 pages in 2 days
Didn't that thread end up getting deleted when the OP got all offensive?
ban-all-sheds said:Why on earth should someone have got all offensive about 3-phase power?RF Lighting said:crafty1289 said:someone asked this a few weeks ago. someone will give you a link. ended up spanning about 15 pages in 2 days
And gafferson - why do you think that only electricians can tell you why we have 3-phase?
If you have a 3phase supply you'll need a 3 phase meter or 3 single phase meters, if you have a single phase supply a single phase meter will do.TheGaffersSon said:Many thanks to all that have posted so far.
Can you tell me, why are 3-phases used to connect to a metre. I fitted one the other day, and didn't like not knowing why I did so.
Which is why a 3phase motor is a lot more efficient than its single phase counterpart.Another question. I may be wrong but is 3-phase used, because the magnetic field produced can make objects rotate by all three at 120 degrees pulling it towards them?
To make a 3phase motor spin the opposite way you swop two of the supply phase wires to it over.I was told if you fit a 3 phase item incorrectly (ie the wrong way round) it can work in reverse. I assumed this was because the magnetic fields would be different.
If the power waveform was purely sinusoidal then you'd never get any power through (which btw is what happens if you connect a perfect inductor or capacitor to an AC supply, theres voltage and current but no net power)Softus said:Indeed so, but is the power waveform not also sinusoidal?
No but you could ask me about caulking decking on a ship using a caulking iron similar to leaded soil pipe joints.....one use for old ropeTheGaffersSon said:ban-all-sheds said:Why on earth should someone have got all offensive about 3-phase power?RF Lighting said:crafty1289 said:someone asked this a few weeks ago. someone will give you a link. ended up spanning about 15 pages in 2 days
Well not ONLY electricians, but mainly electricians. I wouldn't ask a plumber about decking screws now would I ?
