a thank you to weareleeds
1 Feb 2006
Hi weareleeds did as you said and lo and behold its cured the problem, now i only need to know how to restrict the flow to 11Litres or so, the manufactrurers guide says it can run at 16litres but i get the feeling that if its run to long at to fast a flow it will burn somethnig out sooner or later?
cheers
Paul
how about posting this on the original thread...so we know what ur on about
it was last week mate but i have a vokera linea and the hot water flow rate had died on it to a trickle its only 3 years old or less but weareleeds told me to take out the flow restrictor at the dhw point, which i have done to great success ut now need to know how to restrict the flow as i mentioned.
Use black tap under boiler (mains supply) time how long to fill a 1 litre jug should be about 6 seconds if it is quicker than that turn tap down till it's at that rate hey presto approx 35 deg temp rise (assuming blr working correctly)
