For 3/4" valve, the price of these tiny washers seem to be going for anything between £6.50 - £10+,
Is it not £1.05 for 2 from toolstation?
Yes.Is it not £1.05 for 2 from toolstation?
Are you sure it's 3/4" Looks like 1/2" to me, much more common in a house. The OD of the 1/2" BSP thread is 21.4 mm, 0.84".Yup. For 3/4" valve,
What is the OD of the threaded part through the tank wall?Yes, the old valve has 3/4" fitting - bolt and nut through the water tank connecting to the Tee connector (3/4" in the centre). Not 22mm, not 15mm, not 1/2".
Search eBay for 3/4" ballvalve washers with no hole, and the price is between £6.50 - £10 each.
We decided to install the new PART2 valve when it arrives.What is the OD of the threaded part through the tank wall?
What's the OD? That will settle whether it is 1/2" or 3/4".We decided to install the new PART2 valve when it arrives.
Will be taking out the old valve and just store it in the shed for repair through time.
They look like for 1/2" valves which are more common. The one we have is definitely 3/4" valve.
It's 1/2 inch BSP...my fifty years tells me that. A 3/4 inch would have a bigger float.What's the OD? That will settle whether it is 1/2" or 3/4".
I just meant that it wouldn't fit solidly in the valve. There would be very slight movement up and down and, also, left to right. I'd expect the washer you've removed to have been jammed in, so the new would feel slightly "sloppy" in comparison.What do you mean by a loose fitting but not so loose that it falls out?
If you put a half-inch washer in a three-quarter inch valve then I'd expect it to fall out, so that would be wrong.
Do that, then fit it. Job done.am waiting for the new 3/4" PART2 high pressure valve to arrive.
