Abacus Elements Board to Blockwork for Tiling
3 Jan 2018
I will be waterproofing my shower area in the near future with elements board, and one side will be approx 3 meters against an internal blockwork wall that will have had the old tiles stripped off.
I am a bit unsure how best to fix them to the wall. The ones against stud wall have screws which are ideal but on masonry I can't seem to find a definitive answer. even on the manufacturers website.
I see some YouTube videos Dot and Dab, but I am not really sure why. Is this to make it easier levelling them? If so my walls are pretty straight and surely the tiler can take any slight variation out?
Is it better to use adhesive?
If mechanical fixings whats the best approach as plugs and screws seems like it would be a hassle to drill, remove panels for plug, refit etc. I see there seems to be some fixings which you drill and hammer straight through but never used these before so a bit unsure if best suited to this. Would I then also need adhesive, dot and dab?
Any pointers for this specific elements board would be much appreciated.
Anyone have any advice on how best to mechanically fix them to plastered wall after removing the tiles?
