    Dismiss Notice
ABV for 42mm pipes
Discussion in 'Plumbing and Central Heating' started by DIYWell, 14 Sep 2021.
  1. DIYWell
    DIYWell
    9 Nov 2009
    298
    Thanks Received:
    11
    Edinburgh
    Country:
    Big conventional boiler, no ABV in the system afaik. Are they readily available for 42mm pipes?
  2. Sponsored Links
  3. jeff the gasman
    jeff the gasman
    8 Dec 2007
    13,755
    Thanks Received:
    5,072
    Cheshire
    Country:
    Firstly, what’s an ABV?
    • Like Like x 1
  4. DIYWell
    DIYWell
    9 Nov 2009
    298
    Thanks Received:
    11
    Edinburgh
    Country:
    Automatic bypass valve
  5. jeff the gasman
    jeff the gasman
    8 Dec 2007
    13,755
    Thanks Received:
    5,072
    Cheshire
    Country:
    42 x 42 x 22 tee. with 22mm bypass.
  6. dilalio
    dilalio
    20 Mar 2009
    7,937
    Thanks Received:
    1,293
    Potters Bar
    Country:
    Alcohol by Volume ;)
    • Like Like x 4
  7. DIYWell
    DIYWell
    9 Nov 2009
    298
    Thanks Received:
    11
    Edinburgh
    Country:
    I'd have thought if the boiler has such big feed and return pipes, the bypass would have been a beefier thing than the usual 22mm, but hey, what do I know.
  8. jeff the gasman
    jeff the gasman
    8 Dec 2007
    13,755
    Thanks Received:
    5,072
    Cheshire
    Country:
    Not much?
    • Like Like x 2
  9. Terrywookfit
    Terrywookfit
    19 Jul 2007
    5,776
    Thanks Received:
    1,095
    Country:
    A shunt pump.
    • Like Like x 1
  10. Sponsored Links
  11. fixitflav
    fixitflav
    20 Mar 2018
    1,234
    Thanks Received:
    139
    Stoke-on-Trent
    Country:
    If it's an existing system and there isn't one currently, what makes you think you need one? Just curious
    • Like Like x 1
  12. muggles
    muggles
    28 Oct 2005
    13,342
    Thanks Received:
    3,077
    Daventry
    Country:
    The bypass only has to be able to carry the minimum volume of water required by the boiler, not the full system flow. They're specified by looking in the boiler manufacturer's instructions, finding out what the minimum flow requirement is, then finding an ABV that will deliver that flow. 28mm ones are available if 22mm really won't do it. Larger systems will almost always have a header and so an ABV is not required
  13. DIYWell
    DIYWell
    9 Nov 2009
    298
    Thanks Received:
    11
    Edinburgh
    Country:
    That coming from someone who asked what an ABV was?
    • Like Like x 1
  14. DIYWell
    DIYWell
    9 Nov 2009
    298
    Thanks Received:
    11
    Edinburgh
    Country:
    System was fitted in the early 90s before ABVs were wide spread. There have been instances when the TRVs have closed off enough to force the hot water out the overflow on the roof. Crossed my mind having an ABV added might help.
  15. fixitflav
    fixitflav
    20 Mar 2018
    1,234
    Thanks Received:
    139
    Stoke-on-Trent
    Country:
    Interesting. Usually there is at least one rad without a TRV (the one where the roomstat is), so the boiler gets minimum flow if all the TRVs close. But if all have TRVs and all close, I can't see why the F/E tank would overflow, if that's what you're saying. Though the boiler wouldn't like it. As a stopgap, you could remove the head from one TRV.
  16. jeff the gasman
    jeff the gasman
    8 Dec 2007
    13,755
    Thanks Received:
    5,072
    Cheshire
    Country:
    You need to sort out the hydraulics rather than finding a way around it.
  17. ianmcd
    ianmcd
    15 Aug 2010
    23,521
    Thanks Received:
    9,721
    Lanarkshire
    Country:
    An ABV wont stop pumping over, you have bigger system design problems than that
    • Like Like x 1
Loading...
Share This Page
