Anyone know where I can get a replacement Accenta 6 keypad? My old one's buttons are gradually losing their ability to make contact. I hear that the next model keypad dos'nt work, don't know if that's true or not. I've scoured the Web but no joy. Can anyone help?
However, why don't you strip it down and clean the contacts on the pcb under the keys with an eraser (rubber)? Then wipe the black 'pills' under the keys on a piece of card for about 10cm to clean off the carbon crud.
I've used this technique on loads of keypads and given them a new lease of life. It also works on remote controls (but they're often harder to take apart...)
Hi Eighty Two, Thanks for the tip. I've cleaned it as you suggested and it's made it operate significantly better. Many thanks for your help.
Best Regards,
Jack
