Accenta Alarm flashing strobe
21 Jan 2014
West Midlands
I've just had some electrical work done, which involved cutting the power. This of course set the alarm going. I've used the standard code to cancel the siren but the blue strobe light is still going. They keypad is glowing green suggesting it's got power but the indicator lights are all dark. I've tried using the engineer code to reset a strobe test but this hasn't worked. Does anyone have any ideas how I cancel the flashing light. I've never used the alarm so I'm not bothered if the solution involves a permanent disable! Thanks.
The very first thing is to replace the faulty battery in the control panel.
Did you press the Reset button after you put in the code? When the alarm is activated, putting in the code will stop the sounder, but leave the strobe running. Pressing the Reset button will switch off the strobe, assuming the panel does not have a fault. Europlex also makes a valid point.
I've taken the key pad off the wall and there's no sign of a battery. The LEDs are on but none of the indicator lights are on eg power etc. if the keypad is not working do I need to get up a ladder and take the cover if the siren and manually disconnect the siren and strobe from the battery?
What about the battery in the control panel?
The keypad is NOT the control panel.
Replaced the battery yet?
That is going to be the problem you have, nothing else, that is, other than pulling wires from a perfectly good alarm panel that just has a duff battery.
Doing that should NOT set the alarm going, you have a faulty/old battery.
No more, no less.
