Joe, you know very well that the writing of a tome requires many chapters and volumes.There is no point going one step at a time over weeks. It either works when you reboot it or it doesn't. Let's find out eh? Reboot it.
When your computer crashes what do you do? Yes. Reboot it. No messing around.
.... and that WILL NOT tell you if your battery is faulty.That's fair comment Lee, I've just read your first post again. Walk in front of your passive infra red detectors mounted in each room and tell me if a light comes on on the unit when you walk in front of it.
Lee. Let me tell you what to do.
Pull the fuse carrier out of the spur. - What does this mean? which fuse carrier & which spur? Are you talking about the main power in the house or in the panel?
Open the panel. - Wont this set the alarm off?
Disconnect battery. - Which battery? Ive not seen inside the panel, is there only one? Is this what they say needs replacing?
Count to ten.
Reconnect battery.
Enter code number
If it doesn't come back on then push in fuse tray. The one I took out before? Doesnt one of the fuses need replacing?
If it still doesn't work you need a new panel.
If external alarm sounds disonnect the switched neg and the speaker. - Wheres this in the panel? Is it all labelled?
Get ladders up and remove battery from siren unit. - Not an option!
Remove mains power and battery again.
Panel now dead.
Buy new panel.
Get back to me and I'll tell you what to do.
No need to make a drama out of it.
