Accenta G3 Fault Following Cable Repair
31 Mar 2025
Recently, while installing a laminate floor, I inadvertently damaged an alarm cable.
The details of how it was damaged are extensive, so I will refrain from elaborating further.
I repaired the cable with connectors, but all zones light up on the keypad when I set the system. If I disconnect the cables, the issue persists except for the affected zone that doesn’t show.
Am I overlooking anything?
I’ve also noticed that removing any detector covers does not activate the Tamper.
Any advice is welcome.
Would the keypad still operate? I had a fast blow fuse blow on my alarm some years ago and nothing would operate.
Separate fuse ….do your pirs / detectors light up when you pass them ? If not fuse blown
As below
No that don't, that sounds like it, I'll try that tomorrow thanks sparkymarka
Thanks sparkymarka, the fuse had indeed blown, all working and confirmed with walk test.
