Accenta Gen 4 and strobe light
9 Mar 2009
Essex
I've got an Accenta Gen 4 and want to wire a blue strobe light to it, the light has got just 2 wires from it, I've wired it to the strobe + and - but not working.
Any ideas?
Fuse is ok....gonna try the strobe directly connecting to the battery to test it as bought it a while ago and it's been sitting in the garage.
So am I right wiring it to the strobe + and - ?
How did you test the output?
There is a test menu, or just set it and trip it.
I have wired in the blue strobe to the strobe + and strobe - in the panel.
To test the strobe i went into engineer mode/test outputs/strobe.......didn't work.
I have since wired the 2 wires from the strobe light directly to the alarm battery and the strobe worked????
Have I wired the strobe correctly in the panel???
Yes, do it again on the battery and when it works mark up the pos and neg wires.
Then fit accordingly in the panel.
