Hi after some advice re my alarm which I'm unable to set due to setting fault. The fault is showing back door. I've checked the wiring into the white block and seams. Also I have the back door set to chime when it's opened and this works fine. From this I'm guessing the wiring is fine and the sensor is fine.
So to recap can't set alarm due to error stating setting fault back door. Thanks Jeff
