I'm having a problem with the final part of installing an access control system.
I need to fit some kind of magnet to a PVC door, which will work with the panel. When i've fitted these before the door has not been a cheap double glazed door and i put in a electric release rim mortice lock. However because its a double glazed door won't work.
So i've looked at a Door magnet, but following the instructions it will not allow me to fix the magnet to the wall due to the over hand being about a foot. Is there a way of fitting a door magnet onto the side area of the door (as theres alot of room to the side).
Or is there a way of fitting an electric realice rim lock to the outside of the pvc door?
Its probably simple to fit the magnet to the door etc but i just cant get my head round it?
Cheers
Cheers
