You need to stop the sound vibrations getting into the fabric of the building. Insulating afterwards is futile.
I've just installed these but as has been said above...it's a bit of a slippery slope. If you're not willing to go the whole hog and ensure that everything is fully sealed to allow no sound through, then you may as well just use standard plasterboard. To be at their best, they should be on resilient bars fixed back to the studs. Everything just be finished with acoustic sealant etc....it's alot of work and money to do it properly, and if you start to cut corners, you may as well not bother.
I've came to the conclusion that as I got the acoustic plasterboard (Gyproc SoundBloc in my case) for the same price as standard, I'd just use it anyway. If it helps, great...
