We're planning to knock through a load supporting wall and hold up two pairs of existing RSJ's with a steal column. The column has been calculated to need 152x152x23kg UC
What is the appropriate way to acrow the steal beams while removing the wall supporting one end?
Considering there are 2 steels for each side of the cavity, would you put an acrow under each steel or support both steels with one acrow and some sort of block between the two?
