The paint companies recommend using acrylic eggshell over oil based to bring it up to a water based system, however adhesion is a real problem..I have done this on a small cupboard, you could peel the water based stuff off with your finger nail...not good
Its also been know to ciss/cess up because your putting water over oil
I would give it a really good rub down a coat of acrylic primer undercoat then your acrylic eggshell
Thanks again Zampa. Is the acrylic primer/undercoat not water based as well? Presumably has properties that will avoid the potential problems you mentioned.
