Hi
I just been asked to install floor sockets under frezers in cake shop are we allowed to do this!!
Hi
I suppose so.
Assuming the freezers aren't actually sitting on the floor sockets and plugs.
And you're not expecting them to get wet or anything.
What is your actual concern?
Set in the floor, or just on the floor? Set in the floor is common in offices below desks to supply computers. The floor is raised above the sub-floor, with space below for pipes and cables etc.. You can buy special in floor boxes, with flip open lids, which include mains sockets and network outlets.
I wonder why they feel floor mounted is best?
I think I will run separate cable to RCBO in case of trip won't effect the restI don't know whether there is any reg explicitly requiring it, but if a socket is not readily accessible then I would want to see a separate means of disconnection that was accessible.
While on new builds it is preferred that wall sockets should be fitted between 450mm and 1200mm from the floor, FLOOR SOCKETS can go in the floor.I thought 45cm min distance from the floor
