Add top opening window
17 Apr 2024
Hi.
On our windows, (upvc double glazed), the middle non-opening pane doesn’t have a small top opening window above it. Quite unusual.
Can we replace just the middle pane with one that does have a small top opener for venting? Or must we replace the whole window?
New window required.
A top opener requires a transom between it and the glass below, a transom is a frame component that is welded in the factory, retrofit not possible
