Hoping you guys can shed some light!!
I have had light in my loft for a fair amount of time now, but it consists of a pendent and a 3 pin plug.
I am now looking to make a more permanent fixture.
I have been up in the loft to find a permanent feed at the nearest two ceiling roses, but cant find one. The next nearest source is the landing light switch but this a 2-way switch from the hall light by the front door. The switches appears to have a permanent feed when I test it.
Is it possible to take a feed from this switch?
I have drawn a picture of the rear of the landing light switch and the cables that are in place at the moment.
I know that i can drop a second cable down the wall to the switch as I have already done it.
The 2 way light switch wiring has confused me with the way its wired up and the switch says '1way' on the rear, so this is the reason for the question before delving into it
I am hoping that I will be able to change the 1 gang 2way switch for a 2 gang 2 way switch.
Which cable will I need to make the loop from and where will my new brown and blue cables go.
Thank you
Thank you
