Hi all,
We would like to add a new radiator to our living room. The house is a semi which is over 130yrs old so has nice high ceilings, but there aren't enough rads on the rooms to warm the house and in the winter we get mould and mildew problems, particularly on external walls where radiators are not present.
Let me start by saying I know Jack about plumbing, but willing to learn and try. Also, affording a professional plumber is out of the question at the moment.
We have a cellar, and by going down and having a look I can see the following:
There is a thick (guessing at 25mm) copper pipe on the underside of the floorboards. From this two 15mm (I assume) pipes feed a radiator in the hallway (internal wall which divides our house from the next).
From this, two push fit connectors are joined in which feed the radiator in the living room, again against an internal wall.
I want to fit a 300mm x 800mm radiator to the wall under the window. This wall it notoriously cold and one which gives mould/mildew problems.
I have checked my boiler (Ideal Isar HE24) and this has an output of 23.4kW (max). I converted this to BTU and got over 78,000 BTU/hr. I measured the existing rads and used an online retailer to get rough estimates on the BTU they put out and deducted that from the boilers max output and I have 38,000 BTU to play with.
My proposed radiator will put out no more than 3600 BTU.
Firstly, am I working this out right or am I getting it all wrong.
Secondly, is it just a case of draining the system, fitting the rad to the wall, and using the same white plastic piping which feeds the living room radiator to t-in and feed the new rad - then sitting back and have the wife tell me how clever and manly I am?
Any advice greatly appreciated.
