I'm adding a radiator to an existing boiler system that was installed last year (Worcestor 30SI boiler).
I'm trying to keep the amount of flux added to the system down to a minimum by flushing out most of the new pipework, but obivously when I connect the new pipe work to the old it will then be sealed.
Do I need to flush out the system, if so with what? Just water? I have two connections on the supply and return at the lowest point in the system, so I could connect a water hose there and flush the system out with water?
Please help, thanks.
