Currently the shower is fed from a seperate single way consumer unit with a 40amp fuse. This is then connected to the input side of the main CU.
Now I was thinking that I could just replace this consumer unit with a 40A RCD in an enclosure
Problem is the input comes in from the bottom and output is from the top. The new RCD i bought was it the other way round and there isn't enough slack in the cable to change it.
The RCD is a clipsall and doesn't mention supply/load on the terminals rather 1/N and 2/N. Anychance I could use it with the supply on the 2/N side and the load on the 1/N side?
Other optiosn i can think of are to mount upside down or connect after the shower CU just inline rather than instead of.
Cheers Jay
Cheers Jay
